SP50L7HX - problem!!!
Discussion in 'General TV Discussions Forum' started by species8514, Oct 18, 2005.
  1. species8514
    species8514
    Hi guys - just got my new SP50L7HX and there seems to be something wrong with it.
    The picture displays fine, however there is huge amounts of blocking around the dark areas & they look green. The on-screen menu seems ok, but no matter what connections I use, or if its SKY or my DVD player, it shows up. The picture is terrible!!!! agggggghhhhhh :eek:(
    I would like to try reseting the TV but i cant seem to find anything in the manual on how to do this - and when i press the menu button on the remote the plug-play option does not appear, as the manual suggests.
    Really need help here!!!! Is it possible its set on secam or ntsc or something silly & if so how do i change it!
  2. jaypr
    jaypr
    May 29, 2004
    26
    3
    +3
    Probably need to try some of the different colour settings. I find my dark areas look nasty in standard mode but in cinema mode they dissapear :thumbsup:
    Jason
  3. species8514
    species8514
    Thanks for the idea, but the picture is much worse than color settings - its almost like a 70's pop video, something between a negative image and looking at the picture through night vision!!
    Thx guys, G.
  4. Jamesy_UK
    Jamesy_UK
    Sep 27, 2005
    430
    +11
    you'd be surprised species makes a huge difference to have the TV properly setup with a AVIA or maybe THX setup program. I had a similar problem with black like in ocean's 12 DVD when catherine zeta jones is leaving brad pitt's room and shes wearing a blackdress and it looked awful but after i switched to cinema and used THX optimizer it was greatly improved.
    P.S don't ever try to watch a Divx standard quality film thats in the dark a lot or you will be really unhappy hehe, watched Original Halloween I ripped from DVD to store on HTPC last night and even with ffdshow, theatertek 2.0 it looked decidly rough in the spooky scenes. Looks like I have to purchase the HD Divx encoding pack see if that helps.
  5. Tarbat
    Tarbat
    Oct 15, 2003
    2,592
    Easter Ross, Scotland
    +303
    I'd recommend using XVID HD instead. IMO, better, and free.
  6. species8514
    species8514
    Hi guys,
    Thanks for the responses but I sent a file to Samsung to show the problem, and they have said there is def a fault with it - so its going back today and im getting another one tomorrow.
    In case anyone else thinks they have a similar problem i will describe - basically the tv shows the picture ok, but when it trys to show a particular kind of dark green (a good example is when Sky goes to commercial theres a kaki green with sky one written accross the middle) This was showing as as bright bright green - like radar green! Im so technical! You couldnt watch it, Stargate looked liked i'd overdosed on magic mushrooms!
    Oh i have some more info regarding the lamp life and replacement costs. I know there have been allot of conflicting reports on this subject. What i can advise is that Samsung support said that the lamp life was 30000 hrs (pretty impressive if true) & the replacement lamp cost would be - get this..... 50 pounds! I've kept the e-mail so that i can complain when they ask me to fork over 250-350!!!!
    Thx again guys, G.
  7. species8514
    species8514
    I have attached a file to show the problem - hope it comes out ok.
  8. vipergrm
    vipergrm
    Sep 6, 2005
    3,818
    Belfast
    +591
    That looks like Halloween because it is spooky as hell :devil:
  9. species8514
    species8514
    Maybe i have a possessed Tv!! I never thought of getting a priest in.... wait i can hear something.... red room, red room.....
