sp50
Discussion in 'Televisions' started by skintboy, Jun 18, 2005.
  1. skintboy
    skintboy
    hello all, just a quick one. Would the vibration of my centre speaker cause any damage in the long term to the internals if i placed it on the glass base of my sp50?
  2. Razor
    Razor
    Dec 15, 2004
    37,547
    2
    +12,504
    My car system worked alot of bolts lose in my car doors. This was mainy from 3 x 10' subs :D
    There shouldnt be any base from your centre speaker, so you should be ok. The main thing to look for when placing a speaker next to a display is to make sure its sheilded. I would of thought that a centre speaker would meet this requirement.
    Have you considered mounting the speaker above the screen on a bracket?
    :thumbsup:
  3. skintboy
    skintboy
    Yeah i will try that out, thanks for the advice razor. :thumbsup:
  4. Razor
    Razor
    Dec 15, 2004
    37,547
    2
    +12,504
    Cheers :thumbsup:
