SP43L2HX Setup
Discussion in 'General TV Discussions Forum' started by hendern88, Mar 6, 2005.
  1. hendern88
    hendern88
    Mar 6, 2005
    52
    Hi there,
    Firstly sorry if this in one of those 'the info's out there already mate' posts but I've tried.....hope you can help.
    I have the above hooked up to a HTPC ( XP2.6ghz ATI9700 ) via Ixos DVI cable.
    How do you get the best picture using PC/DVD ?
    Sky via scart is great... but not PC/DVD
    How do you access the service menu ( tried the one ending Mute/Power and it funnily enough just powers off the TV ) ?
    Having to use the force 720I option to stop DVDs stuttering is there a better option ?
    cheers
    Neil
  2. NPM108
    NPM108
    Nov 6, 2004
    109
    16
    Note sure which one you are referring to but with the TV in standby (ie Off), if you hit INFO>MENU>MUTE>POWER the tv should go into service menu mode at your own risk.
    The with the 1-8-2 power didn't work for me.
