Hi Experts,
I am looking for some advice on which monitor I should go with.
Essentially all my monitor will be used for is stock charts (www.esignal.com). If you image Google for esignal fx line chart you will what I mean.
Now the SP2309W has a resolution of 2048x1152 and the S2309W has a resolution of 1920x1080. What I am worried about is that on the SP2309W model the lines on my chart would be very small compared to that of the S2309W. For my requirements what do you people think would be better?
Also if I bought the SP2309W model and decide to change the resolution to 1920x1080 would this then replicate the S2309W model?
Any input would be appreciated.
cheers
cheers
