SP2 hosed my HTPC
Discussion in 'Desktop & Laptop Computers Forum' started by Mr.D, Aug 29, 2004.
  1. Mr.D
    Mr.D
    Jul 14, 2000
    11,167
    +1,210
    So after going through the rigmarole of swapping my HTPC over to XP pro from W2K and then switching half the settings off to get it working nicely. I install SP2. Theatertek promptly stops passing sound correctly after the dvd menu!
    Luckily I used Acronis trueimage to image the boot disc beforehand and all is now well. I'm not too bothered as I know TT 2.0 will be along in a couple of weeks anyway which gives another opportunity to install SP2 and see if it works.
    Ah well I'll just have to watercool the HTPC in the meantime!
  2. Quantum
    Quantum
    Dec 14, 2003
    238
    Smethwick Nr. B'ham,UK
    I can't believe SP2 poleaxed a senior member! Sorry to hear that Mr D! Anyone else got issues like this with Theatertek and sound after SP2...or any other HCPC issues post SP2 install? I am waiting till I come back off holiday to install SP2 as I don't have time to sort it out if it goes belly up beforehand....
    Paul
  3. stlic
    stlic
    Feb 17, 2004
    762
    +19
    Installed SP2 on some 5 machines without any issues. Theatertek and sound work as well as always. Actually very impressed with this SP2, simultaneous login on RPC is just great.
  4. BBD
    BBD
    Mar 13, 2001
    442
    Lutterworth
    +3
    I've installed SP2 on 3 machines one with TT. TT works fine after the upgrade but I had a bit of fun sorting out my wifi network connections!
  5. Yandros
    Yandros
    Oct 13, 2003
    2,714
    +528
    Only tried SP2 on one PC so far - a brand new machine. I installed an oldish version of ZoneAlarm (4.5) and as Zonealarm started up I got the "Blue screen of Death". I had to remove it via Safe Mode. I think I had the XP2 firewall enabled at the same time (BIG mistake).
  6. UrbanT
    UrbanT
    Jan 6, 2002
    13,277
    Aldershot, Hants
    +3,033
    Another SP2 user. Slipstreamed my XP disk and loaded fresh onto the machine. Not a single hitch in 2 weeks. So far, has been a big thumbs up :)
  7. Steve Bate
    Steve Bate
    Nov 10, 2002
    680
    Tarporley
    +11
    No probs with SP2 and TT here either, running on 3 PC's.
  8. Ajax
    Ajax
    Feb 4, 2004
    170
    Hello,
    What does SP2 add to XP? Is it anything useful?
    Ajax.
  9. cameronl
    cameronl
    Aug 13, 2002
    1,217
    38
    +11
    sp2 killed my xp htpc. I now have gone back to service pack 1 and am doing incremental updates :)
    CaM
  10. Embarker
    Embarker
    Apr 19, 2004
    1,677
    Garden of England
    +71
    on my laptop and my htpc, all fine here touch wood............
  11. cowtipper
    cowtipper
    Jan 29, 2004
    165
    19
    Same here no probs
  12. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    A lame but better than nothing firewall, minor updates to IE which Firefox, Opera et. al have had for ages .. not much.
    The BIG thing though is that future patches for security holes in IE etc. are bound to presume the presence of SP2 so if you don't bite the bullet and apply it at some time in the future you'll not be able to apply further patches.
    I've installed on 2 PCs without a glitch, however my HTPC will stay on SP1 since I have no need for security on it.
