sp ryan the haunting u571 , have the r2 vertions of these got exactly the same sound
Discussion in 'Movie Forum' started by mick23, Jun 24, 2002.
  1. mick23
    mick23
    Mar 20, 2002
    801
    uk
    these disks seem to be recommended for lfe and bass sound effects, saving private ryan, u571,the haunting my dvd player is r2 only, so if i purchase or hire any of these will sound be the same as r1 disks ie choice of dts ,dd or ex or es etc thank you
  2. tee
    tee
    Sep 17, 2000
    2,711
    71
    Close by
    +50
    As far as I'm aware Private Ryan DTS and the Haunting DTS-ES are only available in American, ie. R1. As for the U-571, the DTS soundtrack is exactly the same, although I'm sure I remember something about the R2 version being framed wrongly? Can anyone confirm this?
  3. mortimar
    mortimar
    Jan 14, 2002
    45
    Northampton
    You are correct U-571 Is in 2.35:1 on Region 1 and 1.85:1 on Region 2 . Only R1 has the DTS.
    I think the German R2 had DTS but not sure if this is in just the German language only?
  4. kevb
    kevb
    May 16, 2002
    1,099
    41
    About
    +3
    U-571.
    Someone got here before me.
    The R2 is framed in 1:85 not the original aspect ratio and is DD only. The R1 has the original aspect ratio of 2:35:1 and has both.
    If a film is in DD EX at the cinema it will be the same on the DVD. This is because of the way the soundtrack is transfered to dvd. The same is also true for DTS-ES. DVD may not be labelled up as such but the extra channel is there.
    The DD and DTS soundtracks should be the same for both regions (apart from the difference in formats). Although somtimes the bit rates (Quality: Changed so that certain people don't flip their lids) can differ between regions.
  5. Oblivion
    Oblivion
    Feb 23, 2002
    524
    Milton Keynes
    Higher bitrate doesn't equal higher volume.
    Higher video bitrate doesn't equal a bigger picture.
    Higher bitrate equals more detail
    Paul
  6. kevb
    kevb
    May 16, 2002
    1,099
    41
    About
    +3
    I knew someone would come out with this.
  7. Oblivion
    Oblivion
    Feb 23, 2002
    524
    Milton Keynes
  8. kevb
    kevb
    May 16, 2002
    1,099
    41
    About
    +3
    :mad:
  9. kevb
    kevb
    May 16, 2002
    1,099
    41
    About
    +3
    :mad:
