SP/DIF on a turntable ?
Discussion in 'Hi-Fi Stereo Systems & Separates' started by iwatkins, Dec 17, 2002.
  1. iwatkins
    iwatkins
    Hi All,
    I'm looking for a turntable for the house as we still have a huge amount of vinyl that the missus (and if I'm honest, myself) doesn't want to consign to history.
    So I'm looking to buy a turntable that will be connected to our AV amp (Sony STR-VA555ES) that we are both happy with musically.
    Now, I was just going to buy a turntable and connect up as normal to the phono inputs on the amp.
    However, during my search I've come across a couple of turntables in my price range that have a SP/DIF output. I.e. I could hook it up using an optical link to the many spare optical inputs on the amp.
    Has anybody any experience of these turntables and do they affect the sound ? I would guess you are looking at an analogue to digital conversion for the ouput on the deck and then a digital to analogue conversion back on the amp side.
    At least the signal should be safe in transit in what is a electrically noisy corner of the room.
    Any thoughts welcome.
    Ian
  2. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    High Wycombe, Bucks, UK
    +59
    You're better of looking at good 'normal' deck without the digital output, the only ones of these I've seen have been for DJ'ing purposes.
    I would start from the Rega P2, £199 +cartridge
    Classic deck been around for about 30 years now, with a few updates mind.
    Depends on your budget, how much did you have in mind?
  3. iwatkins
    iwatkins
    Hi Richard,
    Yes, the decks I've seen with digital output were aimed at the DJ'ing world, but looked of high quality.
    My budget is around the £300 mark but as I haven't bought a turntable in the past 15 years I'm not really very knowledgable as what is good and what is rot ;)
    I'll take a look at Rega which sounds reasonable price wise.
    Ian
  4. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    +59
    For £300 you could get a P2, a decent cartridge, around £40-60 and a project phono stage which is £40. That would certainly be a good starting point.
  5. Flimber
    Flimber
    Sep 22, 2002
    13,719
    Yorkshire
    +4,483
    The old Marantz vinyl -> sp/dif 'de-clicking' units crop up on ebay every now and then but they're £200+. RS cleared these out in ~'91 for peanuts.
    You can always get a line-level convertor for ~£20 and use that.
    HTH,
    Mike.
  6. dts_boy
    dts_boy
    Nov 26, 2001
    2,669
    Manchester suburbs...
    +215
    and heres me thinkin that turtable and digital output were two words not allowed to be used in the same sentance!
    i have recently got a project rpm4 and am very happy with it, was about £300, although that is a discounted price.
  7. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    +59
    Just to reopen this thread.
    I bought a Rega P3 deck last weekend, and very pleased with it I am. Just need to get a decent selection on vinyl to play on it now.
  8. overkill
    overkill
    Nov 6, 2003
    11,855
    Murkeyside
    +1,207
    Nice!!! I cant imagine why anyone would want a turntable with a spdif output!! A Phono output is miles better quality then spdif anyway!!!:confused:
    Have you got a decent phono stage to go with that?
  9. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    +59
    At the moment I am simply running into the phono stage of my Denon AVR2800. When I get my AVR300 later thsi year I will get a Project SE stage to run with it.
