Question Source for a replacement Yamaha triangle MIC stand
Discussion in 'AV Receivers & Amplifiers' started by BoilingFrog, Jul 16, 2017.
  1. BoilingFrog
    BoilingFrog
    Apr 12, 2015
    4
    Bristol
    +3
    HI all. I am just about to snap up a refurbished bargain of a Yamaha RX A3050. However, it is supplied minus mic, stand and remote. I can find a remote and a mic from the usual place, but I haven't found anyone supplying the required mic stand for angle measurments.
    Does anyone know where I might procure one of these please?
  2. tony nevitt
    tony nevitt
    Dec 20, 2013
    203
    28
    +52
    Yamaha uk would be a good starting point. Most companies have a spares department for all sorts of electronics.
  3. BoilingFrog
    BoilingFrog
    Apr 12, 2015
    4
    Bristol
    +3
    Yes, I will pursue them in office hours. I just wondered if anyone had any other suggestions.
  4. Deleted member 598831
  5. BoilingFrog
    BoilingFrog
    Apr 12, 2015
    4
    Bristol
    +3
    Thanks! I just sent an email.
  6. dante01
    dante01
    Mar 5, 2009
    46,310
    +11,120
    This thread includes a link to a Yamaha replacement parts stockist:
    Question - Yamaha RX A3070 YPAO Mic
    I've a feeling that you'd more than likely have to buy the entire YPAO mic in order to get the associated stand?
  7. Leelo
    Leelo
    Mar 12, 2015
    227
    Shropshire
    +64
    Probably better off looking at getting something like a camera tripod or a Mike stand. I think that’s what Dante uses. I use a camera tripod myself as they have the same thread as a mike stand and that’s what Yamaha put on the bottom of their mikes
  8. dante01
    dante01
    Mar 5, 2009
    46,310
    +11,120
    The Yamaha YPAO calibration uses a special stand for calibration of the A3050 that allows it to measure both angle and height during the calibration.
