Soundtracks
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by hm671, Sep 8, 2005.
  1. hm671
    hm671
    I've been helping in make a promo video for a small UK chairty. All the video has been edited but we are having difficulty with the soundtrack.
    Well it's actually finding the soundtrack - where can I get hold of music without the artist singing over the top (we just want instrumental versions)?
    We would be willing to pay if we had to, but it is possible with certain software to remove a vocal from a track?
  2. Paul_Maycock
    Paul_Maycock
    Have u tried copyright free music cd's?
  3. Roy Mallard
    Roy Mallard
    There are some karaoke apckages that attempt to remove vocals, but they tend to remove everything within that frequency, ask your karaoke MC for a copy of backing tracks next time your in the bar...
    Beware however, aggressive copyright lawyers don;t have any concept of goodwill or charity. Go down the copyright free cd route (worth buying for your own library anyway) or use a package such as apple soundtrack.
    As the person psuhng the buttons you will get your arsium sued (legal phrasing) not the charity, if they are using the video publicly you are taking a huge risk. Ignorance of the law is no protection from it.
  4. hm671
    hm671
    It's main use will be internal , new staff etc. odd bits off sound needed hear and then - does the 30sec rule thing count?
    where do i get copyright free cds?
  5. Brian110507
    Brian110507
  6. Paul_Maycock
    Paul_Maycock
    Another source is NVM Digital who are located in Lancaster. Web address is www.nvmdigital.com, you can also get a free CD sampler from them aswell.
