Soundsticks vs Aego M vs Z 2300 vs Companion 3
Discussion in 'Home Cinema Speakers' started by supernick90, Jan 15, 2008.
  1. supernick90
    supernick90
    Jul 24, 2007
    178
    16
    As the title suggests, i am struggling to decide which 2.1 speakers to get. They are intended to replace my hifi and so sound quality is important, although style is also quite important too. I hope to use the speakers on my LAPTOP and my XBOX 360, although i dont mind buying an extra cable to split between the two.
    What are your reccomendations?
    :lease:
  2. supernick90
    supernick90
    Jul 24, 2007
    178
    16
    Anyone?
  3. supernick90
    supernick90
    Jul 24, 2007
    178
    16
    Aaaaaaaaaaargh......bump!
  4. Sleepy
    Sleepy
    Sep 29, 2007
    845
    28
    +43
    i have the Aego M and the Z-2300.
    The Z-2300 is good for the price, but the sub is a little over powering, even on the lowest setting.
    The Aego M is very good, there is a lot more detail and the sound is clearer. by far the better of the two.
    cant help you with the soundsticks.
  5. supernick90
    supernick90
    Jul 24, 2007
    178
    16
    Any weaknesses with the Aego M? Would i be able to plug in both my 360 and my laptop? Do you think it matches low end hifi in terms of sound? How is it for movies?
    Thanks mate
  6. supernick90
    supernick90
    Jul 24, 2007
    178
    16
