Sounds outputs
Discussion in 'Blu-ray & DVD Players & Recorders' started by fowlersrs, Jun 9, 2008.
  1. fowlersrs
    fowlersrs
    Feb 12, 2008
    391
    +44
    Im after some advice, ive just tonite managed to connect up my PS3 to my Onkyo 506, outputting some nice sounds on my mordaunt setup..
    what I struggled with was getting the audio to broadcast over all the speakers, now ive got a hdmi lead going to the reciever then to the tv, and a optical connection for the audio...
    only was I could get it working was by selecting out in DTS via the optical cable, there was dolby 5.1 option there but I couldnt get it working, I dont really understand all these different formats tbh, which is best and what should i be aiming to achieve, will dts provide me with 5.1 surround sound?
    :confused:
  2. Davieboy00
    Davieboy00
    May 16, 2008
    1,450
    In the Short Forest , with the toads , near Camari
    +173
    DTS is another surround format so will give you 5.1 sound.
    Not sure about setup on PS3 or the Onkyo - sounds like having to match PS3 output with the receiver.
    Sorry can't help any more.
  3. paulst10
    paulst10
    Dec 16, 2004
    12,435
    Essex
    +1,838
    Moved from Speakers to Blu-ray DVD Players :smashin:
    Have you re-optimised the PS3 ?? .. when switched OFF, hold down the power button for 5 seconds until it beeps .. give this a try as mentioned in the post above, the PS3 needs pairing with the amp :smashin:
  4. kingfats
    kingfats
    Dec 29, 2006
    36,741
    Windsor
    +8,826
    Hi mate. :)
    Check your PS3 optical settings. :smashin:
    Also,won't hurt to post and ask in here aswell.
  5. kunal_x
    kunal_x
    Jun 10, 2008
    Buddy , although optical cable are good for sound you will not get any HD track output from optical port. Rather set the ps3 to output the sound from HDMI.
    Regarding you 5.1 question your games need to have 5.1 audio , if they are select dts and LCM out.
