Soundproofing
Discussion in 'Home Cinema Speakers' started by Bleach, Jan 13, 2003.
  1. Bleach
    Bleach
    I wasn't sure which forum to put this in, so I thought I'd put it here.
    Anyone know where I can get some decent soundproofing material? I live in a 200 year old cottage with some very 'quirky' features including an old walkthrough into the house next door!! This has been boarded up many years ago (on their side) and used as a cupboard on my side of the house (usefull for my amp etc..) The problem is that they can hear the bass sometimes from my subs, they're ok about it but I'd like to block it out.
    So my question is, is there some good soundproofing material I can use which will block out sounds going through the thinish (it's about a foot thick) wall? About 5 foot high X 3 foot wide?
    Cheers,
    Col
    Ps/ Egg boxes are out of the question :p
  2. Nobber22
    Nobber22
    Jun 6, 2002
    2,982
    Berkshire
    +111
    Have a look in the DIY forum on this site - those guys are experts at soundproofing. :)
  3. Bleach
    Bleach
    Ah ha! Cheers mate, I'll have a look around there. Thanks.
