Soundproofing
Discussion in 'Home Cinema Building DIY' started by lnewey6, Jun 18, 2005.
  1. lnewey6
    lnewey6
    Nov 10, 2003
    196
    derbyshire
    +3
    Hi I've Just Finished My Home Cinema Room Pictures To Follow. I've Been Looking How To Soundproof For Months .just Finished My Wall I Did 3*2 Studs With 2 Layers Of Plasterboard And Sealed All The Edges .then Left An Inch Gap And Used 2*2 Studs 2 Layers Of Soundblock And Sealed All The Edges Do You Think That Will Of Done The Trick I Hope So I Usually Listen To Movies On My Denon 3802 At About -15 Grat Forum By The Way Can Anybody Recommend A Decent Plasma
  2. lnewey6
    lnewey6
    Nov 10, 2003
    196
    derbyshire
    +3
    anyone
  3. Jamiroquai78
    Jamiroquai78
    I did 4x2 stud with 2 layers of plasterboard and a 2" air gap and it works a treat, if you then have done another double skin it must be bloody bombproof :eek: :D
  4. Jazz Monkey Jr
    Jazz Monkey Jr
    Jan 10, 2005
    14,242
    2
    4
    137
    Garstang, Lancs
    +1,625
    Panny PV500 - hi def ready - top picture - loads of inputs
