soundproofing
Discussion in 'Home Cinema Building DIY' started by lnewey6, May 13, 2005.
  1. lnewey6
    lnewey6
    Nov 10, 2003
    194
    derbyshire
    +3
    hi everyone im hoping for a few pointers first off. i need to soundproof big time .i can only use 2*2 studs i will use neostrips for the top , sides and bottom plates . is it worth using resilent channel and 1 layer of 12mm soundblock then sandwich the green stuff what they use for laminate in between then 1 layer of 15mm soundblock then seal or the edges . hope some one can help cheers
  2. mattym
    mattym
    Jul 31, 2003
    2,116
    maidstone
    +101
    that sounds good(pardon the pun)
  3. 5ergo
    5ergo
    Mar 7, 2005
    91
    9
    Sory but i think its yours neighbours duty to do the soundproofing not you!
  4. jeebas
    jeebas
