soundproofing??
Discussion in 'AV Stands, Cabinets, Seating & Furniture' started by ScoobyDoo69, Nov 10, 2004.
  1. ScoobyDoo69
    ScoobyDoo69
    hey guys, i'm looking to sound proof my room so as not to annoy others when i'm watching films or listening to music... what do you guys recommend? would i have to put it to the brick and then plaster over it? could i use car sound matting? put wall paper over it etc?
    cheers guys
    Kosta
  2. andrew markwort
    andrew markwort
    Jun 20, 2004
    1,156
    63
    +159
    My dad was a sound engineer until he retired and I once asked him the same question. His answer was:
    (a) move house
    or
    (b) buy a set of headphones
    Really effective soundproofing costs a packet, apparently.
  3. Thunder
    Thunder
    Feb 26, 2004
    1,830
    41
    +14
    You need to build a room within a room. Make a stud wall using Gyproc soundlboc plasterboard and fill the cavity with rock wool :D
  4. pemberto
    pemberto
    Oct 14, 2003
    502
    28
    Huntingdon
    +32
    Kosta,
    Have a look in the DIY section of these forums. This topic has been discussed many times over the months and you should be able to find all the information you need.
    Also have a look at http://www.customaudiodesigns.co.uk for products and associated costs.
    Hope that helps.
    Pemberto
