howieeb
Hey guys. I've been doing some research on soundproofing and feel like I have some grasp of the basics. Decoupling, mass, dampening, absorption. My problem is having zero diy skills and having to do this as part of a new build. So coordinating with builders, electricians etc on a busy site. I've now approached 4 companies for a quote and for our room (7m*5.1m. 2.5m high) it averages at around 16k. That's for materials and installation on walls, floor and ceiling. Not including door and plastering afterwards. So 18-20k all in. We can't afford that. What i'm struggling with now is finding a half way house - if such a thing exists - or something relatively simple/cost effective we can ask the builders to do while doing the rest of the house or have a stab at ourselves.
This is where i'm at for the minimum that's worth doing and would appreciate a sanity check. Decent density slab mineral wool for insulation, 2 layers of thick accoustic plasterboard with greenglue compound/sealant. Putty for the electrical boxes and a sturdy fire door. Someone also suggested putting chipboard down on the floor too.
Does this sound like it will have some benefit, or is it chucking money out the window? Is there anything else you would suggest? We don't mind spending money on this - we just can't spend as much as a fully fitted kitchen. Any advice/suggestions would be much appreciated.
