Soundproofing Help
lnewey6
just a quick question my wall is shared next to my room mate its a stud wall with plasterboard both sides i wanted to strip it and start from scrath but its rented the only thing i can do is space out about a inch then build a stud wall insulate then 2 layers of rockwall do you think this will work
mattym
MLV, Resilient channel or green glue, any of those will do, though MLV or GG will keep in your 'spacing'
mattym
greenglue needs to be sandwiched between 2 solids, be it mdf or plasterboard to work, constrained layer dampning is the technical term. Best applied in wall construction, like if your building from scratch or if your building out the wall. lots of installation advice on audioalloy site.
The figures from independant lab testing suggest it does indeed work well and the testimonials suggest it also does what it says on the tin.
Rickyj at Kalibrate
AVForums Sponsor
Hi MattyM,
I am very interested in the Green glue that you have been talking about. I have looked on the website, but there do not seem to be any costs yet? Are there any, and is it available to purchase in the UK yet?
Also will it work if it is applied between an exsisting wall and a layer of plasterboard? The existing wall I believe is brick, which has been plastered, but I am not positive, as I am not very knowledgable on this sort of construction work.
Any sort of help on this would be good.
Ricky
mattym
yumyum33 said:
Hi MattyM,
Ricky
Full details will be along soon, i will set up a powerbuy for a short while soon i hope, need to sort that out with Stuart first. :)
mattym
i dont know plasterboard and fiberglass costs, but i will look into it and develope a costing
You would need from 1 to 3 tubes of Green per sheet of Plasterboard, depending on how much soundproofing you would want to acheive(and budget also)
Podcast: Anthem AVM 70 Review, EQing Your Home Cinema Sound System and More...
