Soundproofing Bedroom
Discussion in 'Home Cinema Buying & Building' started by spiidey1979, Jan 11, 2012.
  1. spiidey1979
    spiidey1979
    Aug 14, 2010
    10
    Edinburgh
    I'm going to be soundproofing an upstairs bedroom, involving soundproofing window (secondary glazing), floor, walls, ceiling and door frame, from a variety of sources including Soundproofing noisy neighbours with sound insulation. Soundproofing walls, acoustic insulation for ceilings & floors. Soundproof with Soundstop UK. , Soundproofing UK Sound Proofing acoustic insulation and noise insulation specialists and 1st Secondary Double Glazing.
    In order to do so, I need to first of all strip the room practically bare. I've lifted the carpet, the underlay, the carpet grippers and removed the skirting boards.
    I'm left with a room as follows:-
    [​IMG]
    Uploaded with ImageShack.us
    [​IMG]
    [​IMG]
    [​IMG]
    Numbers in red used to identify walls:-
    Walls 1 and 4 are internal walls separating another bedroom (wall 1) and a bathroom (wall 4).
    Walls 2 and 3 are external walls - wall 2 has a pitched garage roof partly against it and wall 3 faces the garden with nothing either side of it.
    The following pictures show what was/is behind the skirting on each of the walls:-
    [​IMG]
    [​IMG]
    [​IMG]
    My questions are as follows:-
    1. Am I safe to assume that all 4 walls have been plasterboarded, and I can safely knock them all in to reveal (presumably) stud walls (walls 1 and 4) and the external skin of the house (walls 2 and 3)?
    2. Is the skin of the house (behind the plasterboard on walls 2 and 3) breeze block?
    3. Is there a different technique to knocking in a plasterboard wall that is studded behind compared with one which is sitting on breezeblock?
    4. Why do the floorboards not meet the external skin of the house on walls 2 and 3 (see pictures below)?
    [​IMG]
    [​IMG]
    5. Any tips on lifting the floorboards?
    6. How do I remove the plasterboard around the window sill on wall 3 (see picture below)?
    [​IMG]
    Apologies for the long first post, this is a major project for me and I don't want to start anything I'm not confident with.
  2. Chrisharry12345
    Chrisharry12345
    Nov 25, 2008
    4,422
    2
    +1,249
    Hello mate how did you get on with this? how did you sound proof the floor?
    CHeers
