W
WBC
Guys,
The more I read, the more confused I get....Any help and direction you can offer would be appreciated
I own a 50's detached house. Solid in build but due to late nights on Call Of Duty & in preperation of Modern Warfare 2, I need to soundproof to try not to wake the family !!!
I'm due to decorate the bedrooms and am going to be replacing the carpets upstairs so will use Cloud9 or similar to underlay.
I also plan to put some sort of insulation between the joists to reduce the racket from below. Depending on the threads I've searched, I've read insulation will make a great deal of difference and I've read its almost a waste of time/money/effort. So now I'm confused!!
Will Insulation between the joists help? Are there any rules to follow? Should I just buy expensive accoustic mineral wool or are there cheaper products in Wickes/B&Q that are actually very similar in result?
There are a plethora of options of which you won't know the result until you've spent your hard earned cash....
I don't want to spend a fortune but do want best bang for buck. Can you please advise.
Thanks in advance & apols for long thread.
Stace
Stace
