soundcard for dd 5.1and dts
Discussion in 'Computer Components' started by jason t, Jun 8, 2001.
  1. jason t
    jason t
    Mar 4, 2001
    1,709
    48
    kent
    +38
    hi can someone please recommend a sound card
    to connect to my avr2801 to give me dolby digital and dts
    thanks
    jason
  2. Stuart Wright
    Stuart Wright
    AVForums Founder Staff Member
    Jan 24, 2000
    14,772
    7
    2
    167
    Birmingham, UK
    +10,683
    IF you want a budget card, then the £29 Fortissemo card at http://www.downtowncomputers.co.uk/acatalog/downtown_Guillemot_108.html
    should do the trick. I have a similar Fortissimo card with optical output which works fine.
    Ignore the advice about getting a hardware decoder like the Hollywood plus.
    Software decoding with Power DVD is better quality than hardware decoding. Infact in Power DVD, disable hardware acceleration for the best quality.
    Surprising but true.
  3. siymann
    siymann
    You could get the Creative 5.1 Live Soundcard, which has Digital(analog) output (Dolby Digital 5.1 only - i believe), and connect that to your amp.
    Or get something like a hardware DVD decoder card based on the Hollywood plus Chipset (e.g. www.scan.co.uk sell them for around £50), and that outputs DTS & DD5.1 out on Analog, is multiregion, has TV OUT and does Hardware DVD playback, so u don't even waste CPU cycles playing the DVD...
    :p terra cineview dvd decoder card it's regularly on their Today Only page too..
