Soundcard Digital Out to amp Question
Discussion in 'Computer Components' started by mrm3, Feb 7, 2005.
  1. mrm3
    mrm3
    Oct 29, 2004
    2,011
    48
    Cobham
    +94
    What cable do you think/know I need to go from my Creative Audigy 2 Digital Out to Dolby Digital Amp?
    Hopefully this will deliver 5.1 !
    Thanks.
  2. Ayub
    Ayub
    Oct 15, 2003
    6,382
    Bradford
    +577
    i dont know much about htpc but you will need a opitc cable have spdiff enabled on your soundcard and have it enabled on your hi-fi.
    As for dts it works ok i had a problem with ac3 nobody on the forum would or could help so i bought a divx player for 40 quid. I think when you buy soundcards you are meant to look for ac3 pass thru. Like i said i know ****. Sorry if i'm talking rubbish.
  3. probedb
    probedb
    Aug 20, 2003
    2,653
    Sheffield
    +181
    I think you need a 3.5mm mini jack to phono connector.
  4. hoyin
    hoyin
    What digital dolby amp do you have?
    I would guess it either takes optical spiff or digital coaxial.
    You definately want to use either of these two and not a 3.5mm jack to phono as the quality will be better.
  5. mrm3
    mrm3
    Oct 29, 2004
    2,011
    48
    Cobham
    +94
    Yes thanks.
    My amp does take optical spiff or digital coaxial but my digital output on my soundcard is a small 3.5mm socket like the other speaker connections. So what do I buy ?
    Thanks again for the replies.
  6. hoyin
    hoyin
    Oh right my creative 5.1 card has an add on module that gives it a optical output.
    Can you get one for your Audigy?
  7. probedb
    probedb
    Aug 20, 2003
    2,653
    Sheffield
    +181
    Yep as I said earlier you need a 3.5mm to phono lead. Try Maplins or somewhere like that.
  8. mrm3
    mrm3
    Oct 29, 2004
    2,011
    48
    Cobham
    +94
    You may be right though the audigy cards seem to be problematic to say the least ! I have done some research here. The recommendation is 3.5mm (mono) to coaxial. Plus some software settings to enable a true digital output to amp. For the full low down here ...
    http://forum.ecoustics.com/bbs/messages/5/1656.html
    Thanks for your help guys.
  9. mrm3
    mrm3
    Oct 29, 2004
    2,011
    48
    Cobham
    +94
    Also I take it RCA/Phono and coaxial cable are the same thing or at least doing the same job ?
