Soundblaster MP3+ or something else for optical SPDIF out?
Discussion in 'Computer Components' started by Miron, Apr 25, 2005.
  1. Miron
    Miron
    Sep 26, 2002
    1,435
    Vienna, Austria
    +54
    simple question:
    Soundblaster USB MP3+ is stereo soundcard but it has optical digital out. Can it output bitstream from DVD too? (from computer's internal DVD player) On Creative's site there is note about AC3 etc but I am not sure about it. Any proffessionals here?
    If not what simple USB card would be best to do this task? It has to be optical.
    Or do I need audigy 2 zs for that?
    Thanks.
  2. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    I don't have one of these but it I expect it should be possible. Look in your DVD player software for an an audio output option such as "S/PDIF" or "Pass-through" which will cause it dump the AC3 stream out via this port without trying to decode.
    I'm not sure of the software that comes with it, with my Audigy 1 there'as an "AC3 Decode" option in the Surround Mixer that has to be un-set to stop decoding.
