Soundblaster Creative Audigy 2 ZS PCI : Can I heaphones & stereo connection at once?
Discussion in 'Computer Components' started by thestorm, May 17, 2005.
  1. thestorm
    thestorm
    Jul 13, 2000
    547
    East London, UK
    +30
    With reference to the link below..
    I am interested in an Audigy soundcard with output to stereo
    speakers & Headphone. It should also have a Mic IN port and a digital
    spdif INPUT. Does this card have all this?
    http://uk.europe.creative.com/products/product.asp?category=1&subcategory=204&product=4915
    I can't afford to go for that Platinum Pro edition with the "break out" box
    for connectivity. And I can't be asked to keep going behind my PC to disconnect
    the stereo out cable to plug in headphones!
    So I want to permanently plug in headphones and switch of my main stereo
    speakers when I want to listen to just headphones.
  2. stlic
    stlic
    Feb 17, 2004
    762
    +19
    Don't believe so without breakout box. About headphones there isn't as simple an option as duplicating the front stereo to the rear IIRC so both output the same signal (although I remember reading a post that said it had this option); 4 channel would work but you might get some problems in certail proggies.
