soundblaster bass
Discussion in 'PC Gaming & Rigs' started by grayson, May 30, 2004.
  1. grayson
    grayson
    Ive connected my soundblaster audigy2 to my denon amp via 5.1 Analogue, when I play my games the bass is virtualy non existent, I have it connected to coaxal also which gives out a lot of bass but when i play Prince of persia some of the sound effects are that low they become difficult to hear. Please help me its driving me mad
  2. backtothefuture
    backtothefuture
    make sure your volume level is turned up , using the SB's software menu... also I presume you've upped the bass etc from there? put wave/mp3 and cd-audio to max from the mixer control panel as well...
    finally ensure you've tweaked the ingame settings for the games.. I think P.O.P has its own sound/dialogue level setting as well . I also remember the game being quite low in sound since I forgot I had the ingame sound turned down (or was it master volume on pc I had turned down?...either way it was sorted!)
