Soundbar with wireless rears & 4k support
Discussion in 'Soundbars, Soundplates & Soundbases' started by Paul97, Jan 5, 2017.
  1. Paul97
    Paul97
    Jan 20, 2004
    645
    Hartlepool
    +24
    Is there a soundbar with wireless rear speakers that supports 4k? I'm aware that Sony do one but doesn't support 4k, any help is appreciated.
    Paul
  2. UrbanT
    UrbanT
    Jan 6, 2002
    13,312
    Aldershot, Hants
    +3,038
    Hi Paul, Samsung K950?
  3. ellisbailey
    ellisbailey
    Jul 24, 2000
    752
    28
    +47
    Bose Soundtouch 300 with Wireless rears and Subwoofer module?
  4. Paul97
    Paul97
    Jan 20, 2004
    645
    Hartlepool
    +24
    Thanks guys, will check those out
  5. UrbanT
    UrbanT
    Jan 6, 2002
    13,312
    Aldershot, Hants
    +3,038
    Yep, I looked hard at this one but was put off by the average reviews when it comes to sound quality, only having one HDMI input and also some vagueness around what sound formats it accepts.
  6. britishbulldog
    britishbulldog
    Apr 17, 2006
    100
    +7
    If possible get as many demos of the various brands as you can because your ears would be the best judge rather than relying on other people's opinions.
    I have the Bose SoundTouch 300 set and I think it's one of the best for sound quality,but I am bound to say that.:)
  7. deantown
    deantown
    May 14, 2007
    3,221
    watford
    +2,354
    I have listened to this one in JL and Curries, I have to say it's probably the best sound I have heard from any sound bar yet. I haven't read many reviews that knock the sound. Mostly people just downing Bose as a brand. I haven't bought a sound bar yet as I'm looking for something that "does it all" music etc., but this Bose is high on my list.
  8. ellisbailey
    ellisbailey
    Jul 24, 2000
    752
    28
    +47
    I was torn between the Bose and the Samsung for quote some time and demoed both. I opted for the Bose and have been smiling every day since. Its worked flawlessly from day one.
    I agree that more HDMI inputs would have been nice, but as everything goes to the TV I was happy with just one.
  9. ellisbailey
    ellisbailey
    Jul 24, 2000
    752
    28
    +47
    I don't think you would be disappointed if you got it. It`s not cheap as to really get the most out of it you need the sub and wireless rears, but once you have it you will smile every time you listen to a song or watch a movie! That bass...... :)
  10. Paul97
    Paul97
    Jan 20, 2004
    645
    Hartlepool
    +24
    Not to be cheeky but are there any other options that are a little cheaper, I can't afford these 2 options, my budget is around £500-600.
  11. ellisbailey
    ellisbailey
    Jul 24, 2000
    752
    28
    +47
    From my research I don't think you will find all those items within that price band. Something may have to give?
  12. Paul97
    Paul97
    Jan 20, 2004
    645
    Hartlepool
    +24
    Just bought a 65" TV, don't think the better half would be best pleased if spent another £1200 ;)
  13. Sloppy Bob
    Sloppy Bob
    Jul 6, 2009
    3,931
    +3,069
    Does your TV not have enough HDMI inputs to make the 4k on the soundbar just an extra you don't need?
  14. Paul97
    Paul97
    Jan 20, 2004
    645
    Hartlepool
    +24
    I currently have a Yamaha YSP 2200 soundbar with a Hisense 65M7000 TV. I thought I would need a
    soundbar that would accept 4k signals so it process the 4k signal?
  15. Mallett94
    Mallett94
    Apr 11, 2016
    491
    63
    United Kingdom
    +328
    Samsung HW-K650 does 4K passthrough however I don't think it supports HDR passthrough
  16. Sloppy Bob
    Sloppy Bob
    Jul 6, 2009
    3,931
    +3,069
    If you plug everything into the TV and then connect soundbar via either the HDMI Arc or optical cable then no video signal is going to the soundbar. The soundbar only need to be 4K if you're going to use it's HDMI inputs.
  17. ellisbailey
    ellisbailey
    Jul 24, 2000
    752
    28
    +47
    This.....
    All of my inputs are plugged into the TV, then just once cable from the TV to my soundbar. I can get DTS/and DD5.1 this way which is fine for my needs :)
