soundbar with hdmi audio controls on screen
Discussion in 'Soundbars, Soundplates & Soundbases' started by handsomejackuk, Apr 25, 2016.
  1. handsomejackuk
    handsomejackuk
    Jan 17, 2002
    is there any soundbar that has the audio setting overlaid on to the hdmi rather than the small led display on the soundbar which i find too small... i dont think my tv supports arc either...
  2. Clem_Dye
    Clem_Dye
    May 8, 2006
    3,246
    +412
    If you use HDMI arc, then if you change volume and your TV has an on-screen overlay for that then you should see that as normal. The arc function should allow control external audio device volume when connected via HDMI.
    Clem
