Question Soundbar with a user EQ.
Discussion in 'Soundbars, Soundplates & Soundbases' started by docnaz, Aug 17, 2018.
  1. docnaz
    docnaz
    Jul 17, 2005
    121
    16
    London
    Afternoon all. Intermittent poster. I'm looking for a sound bar, or perhaps base, with a user programmable EQ
    Does anyone know what the stated EQ function is on the LG Soundbars? I could not find an explanation on the LG web page.
    As I'm getting older, I'm losing the higher frequencies and I find the mix of many movies and TV shows not helpful for older folks.
    I really want a sound bar with more than just the pre-set movies, music etc. I want to be able to add more treble and cut mid and bass if I need to ie create my own mix.
    Budget about £250.
    Ideas appreciated.
    Many thanks.
  2. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,927
    The Borders
    +3,571
    'I want to be able to add more treble and cut mid and bass if I need to ie create my own mix' - very few Soundbar or Soundbase devices offer that level of control.
    Have a look at the SONOS BEAM - outside of your budget but does offer User Adjustable EQ via the control App, Beam: The Smart Soundbar for Your TV | Sonos
    Joe
  3. zeppelino
    zeppelino
    Jan 24, 2018
    3,933
    134
    UK
    +1,208
    The base I have has four presets, but does allow me to change bass levels - I think most bars/bases do allow you to tweak bass though.
