Soundbar for music
Discussion in 'Soundbars, Soundplates & Soundbases' started by happyslug, Apr 16, 2016.
Tags:
  1. happyslug
    happyslug
    Dec 11, 2012
    7
    So I need something to stream music from my Iphone using Spotify via blutooth.
    I cannot have separate speakers - usual wife not allowing cables blah blah blah ;)
    So considering a good all in one, or a good soundbar - anything to sit under the TV - nothing else will be there.
    If it enhances TV, that's a bonus, but main aim is music.
    Options so far are
    Soundbar - Q Acoustics M4 (approx £300)
    Speaker with optical connection - Marshall Stanmore (approx £250)
    Looking for something < £500 (although liking the Dali Kubic One at £800)
    Any suggestions greatly received - except for telling me I need to go separates - I can't ;)
  2. johnr2110
    johnr2110
    Aug 26, 2006
    2,750
    2
    2
    68
    Eastbourne
    +94
    The Sonos Soundbar might be worth considering. Heard one in Currys last week and was very impressed.
    Q Accoustics BT3 speakers may also be worth a look.
  3. Bbos37
    Bbos37
    Mar 27, 2016
    192
    Malaysia
    +17
    There are plenty of sound bar to choose from, depending on you budget.Chose the one that comes with a wireless sub.
  4. GAS66
    GAS66
    Jan 10, 2011
    244
    Chingford, London
    +20
    Hi there.
    For me. Good though the Dali is... I strongly suggest that you audition the Q acoustics media 4.
    I was shocked at its sound quality, especially with music.
    It lacks all of the DSPs, decoders, and multiple sound modes but it does an impressive job with music.
    Movies and regular TV are good too.
    The Q acoustics BT3 is even more impressive, and is a definite superior alternative
    to most of the sound bars out there.
    Both will sound even better with a well paired sub.
    In my opinion wired sub would be the better choice
    Good luck.
