Soundbar Dead ?
Discussion in 'Soundbars, Soundplates & Soundbases' started by DevonMike, May 2, 2018.
Tags:
  1. DevonMike
    DevonMike
    Jul 7, 2012
    762
    46
    North Devon
    +201
    On Saturday I bought a Panasonic schtbb690ebk to go with my Sony TV,I plugged the PS4 into the connection on the bar,arc to TV,youview box to hdmi 2 and all appeared fine,whilst playing online I was experiencing lag so decided to plug the PS4 directly into the TV and you into the soundbar......nothing,I've reset the youview box,TV and soundbar several times and I get no sound out of the PS4 and no sound or picture from youview plugged into the bar,all cables are good.......return it I reckon....any suggestions?
  2. zeppelino
    zeppelino
    Jan 24, 2018
    2,758
    134
    UK
    +717
    Try everything into tv and hdmi or optical to bar.
  3. DevonMike
    DevonMike
    Jul 7, 2012
    762
    46
    North Devon
    +201
    Getting it swapped over tomorrow as bought the sound bar as it has 4k pass through and the tv only has two 4k ports so I it would kind of defeat the reason for buying it,the tech guy I spoke to earlier suggested that the bar might have a fault.
