Soundbar Advice/Dolby Digital/DTS Query.
Discussion in 'Soundbars, Soundplates & Soundbases' started by Aidan., Feb 4, 2014.
  1. Aidan.
    Aidan.
    Mar 16, 2008
    164
    +6
    Hello,
    I am looking at buying a 2.1 soundbar, but have some questions before I do so.
    My TV is Samsung's LE32B450. It has three HDMI ports and an Optical Out port.
    The manual says the following:
    "When the HDMI IN jacks are connected, the DIGITAL AUDIO OUT (OPTICAL) jack on the TV outputs 2 channel audio only. If you want to hear 5.1 channel audio, connect the Optical jack on the DVD / Blu-ray player or Cable / Satellite Box directly to an Amplifier or Home Theatre, not the TV."
    What does that even mean? When the HDMI input is connected to what? When it says 2 channel, does it mean PCM or 2.1? I apologise if they are the same thing - I am beyond a novice when it comes to this stuff.
    The manual also says that the Freeview tuner makes use of Dolby Digital (Plus, apparently)? What is this exactly? I read somewhere that if I use my TV as a switcher (what does this mean?), it will convert to PCM, which soundbars that do not support Dolby can play. I also read that if I use my TV's Freeview tuner connected to a soundbar, it will send the Dolby signal to the soundbar - but if the soundbar has no Dolby support, no sound will output.
    How does this relate to Optical Out 5.1 and HDMI bit mentioned above?
    The reason I ask is that I want a soundbar to connect to my TV and laptop (laptop has a HDMI jack). I don't have much room though (only room for a soundbar which is 800mm/80cm in width), and don't really want to spend above £150.
    My only option seems to be Maxell's MX-SB252 (no Dolby or DTS decoding support). It has 3 HDMI Inputs, 1 HDMI output, and 1 Optical Input. What would be the best way to connect to my TV and laptop? If I came across a 2.1 soundbar, does Dolby Digital (and/or DTS) decoding support make a noticeable difference?
    I apologise for the long-winded post, but I know absolutely nothing about audio, and wanted to give as much info as possible.
