sound when using xbox highdef
Discussion in 'Xbox Forums' started by sime, Aug 24, 2005.
  1. sime
    sime
    Jul 7, 2004
    140
    +6
    i recently had my xbox modified so i could use it as a high definition player to connect to my latest purchase a sanyo z3 pj and just spent £100 on a hd lead while i await the delivery of my neoya x2vga connector,....is it possible to maybe connect a optical output to your xbox some how as i know a freind of mine as fitted two usb ports to his ..........just a query
  2. John
    John
    Dec 13, 2002
    11,193
    +2,829
    There is an optical out on the official MS hidef pack . I think it may be possible to rig up a coax digital out (possibly seen somewhere on xbox-scene).But I'm not sure about an optical out
    John
  3. CAS FAN
    CAS FAN
    Nov 24, 2003
    35,253
    2
    167
    The Wheldon Road end!
    +8,349
    According to here the unit has optical audio out on it :smashin:
    I must say it seems an expensive route for getting HD when the Component HD pack is only around £16 from here.
  4. sime
    sime
    Jul 7, 2004
    140
    +6
    hi cas fan yeah i know it works out exspensive but, i also want to use the same lead in the future when i get round to buying a hd dvd i am trying to get the setup of my dreams as i have just bought a new house with a decent size room and took out a little extra ,,,,yep i also get to purchase a 360 soon i have bought cheaper leads before and have been un-impressed by the reprodution(poor) qualitys , but saying this i have heard loads of good things about the offical ms hd pack
  5. CAS FAN
    CAS FAN
    Nov 24, 2003
    35,253
    2
    167
    +8,349
    The official HD pack is superb and gives a cracking picture when fed through my Z3. HD material looks fantastic and I can't wait for my 360 to arrive :clap: :clap: .
  6. sime
    sime
    Jul 7, 2004
    140
    +6
    yeah i only picked my z3 up a week ago i love it im using a grandview widescreen i am totally amazed and i am only connected up using the s-video connection at the moment
