Sound/vision sinc problem.
Discussion in 'Plasma TVs Forum' started by Pill Fairy, Oct 3, 2004.
  1. Pill Fairy
    Pill Fairy
    Complete novice to this,
    Just set up my new 42PWD6, connected my sky box via scart input for video, with audio right and left from sky box RCA output to cinema surround system.
    Picture is perfect but sound is slightly in front of vision. Seems more evident on BBC channels.
    Any help would be realy appreciated.
    Thanks.
  2. Justhe1
    Justhe1
    Apr 5, 2003
    46
    Hatfield, Herts
    Yep, its a known problem - just setup my new PW6, and sky was the same. I had sky+ installed 2 days ago, and now have the sound going into my amp via optical digital cable. They also replaced the LMB and tweaked the signel strentgh from around 40 to a high 85/90.
    Don't know if any of the above should have fixed the lip sync prob but it seems to have!
    No probs at all - Oh, I also changed the scart (RGB) lead the goes from the sky box to the JS coverter to a £50 ixos one - there was a def improvement in the pic, so again don't know if that helped...?
    Sorry, no definative answer there, but the above worked for me!!
