Sound too quiet. Any ideas?
Discussion in 'PC Gaming & Rigs' started by kwijibo, Nov 5, 2003.
  1. kwijibo
    kwijibo
    Feb 4, 2002
    475
    essex
    This is probably a really simple thing, but I have just got into pc gaming and have noticed something with my pc I hadn't before. The sound from my little speakers is ridiculously quiet. I hadn't bothered with sound previously, but on radio, downloads, games whatever I cannot turn the volume up past whisper. I have of course checked the really simple stuff like volume control, but that is on maximum. Any ideas?
  2. Bursar
    Bursar
    Jun 29, 2003
    2,406
    63
    Cambridge
    +215
    Have you checked the voluem controls in Windows? There are seperate sliders for the main volume, wave files, midi files, CD audio and so-on. Might be worth upping those.
    There's also the possiblity that the connections between the speakers and PC are a bit loose, so they may need a wiggle.
    How are your speakers powered? If they're mains powered, they should be able to churn out a reasonable volume. If they're not mains powered, that might be part of the problem.
  3. Garrett
    Garrett
    Apr 21, 2001
    40,754
    2
    167
    The best thief you’ll never see.
    +6,858
    Go in the control panel and click on Sound and audio Devices, you can increase it there.
    Also (do not know if this applies to you as I run an amp of mine) make sure you have it in the right socket on the sound card.
  4. Ethics Gradient
    Ethics Gradient
    Jul 29, 2003
    3,681
    aka Billy Science - Suni ojna Tas
    +430
    depending on your particular hardware there may be connections for line out , microphone and speakers - if your speakers are passive and are pluged into the line out they will be very quiet.
  5. Squiffy
    Squiffy
    May 23, 2002
    11,879
    Ashford, Kent
    +5,158
    Make sure you take your fingers out of your ears. :rolleyes:
    Might be worth checking your speakers with another source - just to make sure they're not duff.
