Sound sync issues
Discussion in 'Satellite TV, Sky TV & FreeSat' started by mdean2805, Apr 26, 2007.
  1. mdean2805
    mdean2805
    Dec 3, 2006
    5
    Does anyone else have problems with the sound synch on Sky+. I am used to the ocassional problem but it is either happening more recently or I am more aware of it and noticing it more.
    Is there an easy solution to this issue?
  2. superbike999
    superbike999
    Mar 16, 2006
    242
    Southport
    +19
    If you're using an external Home Cinema amp, try the sound set up menu in the Sky + box. Start at 60ms and see if that fixes it.
    Dave
