Sound Splitter?
Discussion in 'Hi-Fi Stereo Systems & Separates' started by Drew C, Mar 19, 2003.
  1. Drew C
    Drew C
    Feb 24, 2003
    319
    Leeds
    Can anybody let me know where i could buy a device which would let me run 3 pairs of speakers from 1 hi-fi all at once? It may sound strange, but i run a pub, and im wanting the same music in three different rooms.:smashin:
  2. Sunday Ironfoot
    Sunday Ironfoot
    I think your amplifier would struggle to power three pairs of speakers all at the same time, unless it's a seriously powerful amplifier.
  3. Dubbing Mixer
    Dubbing Mixer
    Jan 27, 2002
    643
    By, and sometimes in, the sea
    One solution, and it might even be the most cost effective, would be to have three amplifiers. One would be the master with the other two fed via the tape record outputs. (Either both from the master or looped through. Advantages: separate volume control for each room, ditto tone controls. If you want a master volume control, that's a bit trickier and would depend on what facilities the master amp has.
  4. nathan_silly
    nathan_silly
    You can buy PA type amps, pretty cheap and should do the job, and have more than 2 channels. Musical instrument/DJ shops sell them.
    You don't exactly need a Mark Levinson!
  5. sounddog
    sounddog
    Dec 11, 2002
    3,437
    107
    Leicestershire, UK
    +477
    On ebay you see quite a few Nad 906/916 Amps which are 6 channels amps so just get splitter cables along with one of these.
    They got for around £100ish for the 906 and £150ish for the 916 and there doesn't appear to be much difference between em.
    Steff
  6. AOD
    AOD
    Feb 7, 2001
    714
    London
    +5
    I think some of the Rotel power amps let you drive multiple stereo pairs from one input signal.
    Yep, found it.
    Take a look at this, the Rotel RMB 1066 6 channel power amp.
    Of course this might be more expensive than some of the other suggestions, but it wouldn't half simplify the connections.
