Sound signal converter
Discussion in 'Computer Components' started by richjthorpe, Sep 12, 2005.
  1. richjthorpe
    richjthorpe
    Aug 2, 2004
    2,031
    41
    dat london
    Hi all,
    When I get my PC up and running, I've thought of a problem I might hit with my surround amp.
    At the moment I use Pseudo Suround for Stereo input from Freeview and DD/DTS 5.1 for DVD playback. This switches automatically on the amp because there are 2 inputs and the amp remembers what signal to use (Eg, when I switch to TV for Freeview on the amp, it automatically selects Pseudo and when I select DVD it switches to 5.1).
    When I hook up my PC to the amp, there will only be one connection through coaxial and therefore removing the switching capability on the amp. Is there a utility that can change a stereo signal into a 5.1 digital signal on the PC so that I can leave the amp on 5.1 or do I need a sound card for this ?
    Thanks,
    Richie.
  2. deksawyer
    deksawyer
    May 26, 2005
    1,642
    Fife, Scotland
    +132
    Hi Richie
    your amp should differentiate between a stereo signal (pseudo surround as you say) and a proper 5.1 mix.
    With my receiver, I leave it in Pro Logic mode for everyday TV watching and when a DVD is played it picks up the Dolby Digital/DTS signal no problem and switches on the appropriate decoder.
    This is using the NVIDIA decoder.
    D.
  3. richjthorpe
    richjthorpe
    Aug 2, 2004
    2,031
    41
    dat london
    Fair enough, I'll try that when I get it set up.
    Thanks,
    Richie.
