Sound Setup Disc advice
Discussion in 'Home Cinema Buying & Building' started by kevhky, Jan 18, 2008.
  1. kevhky
    kevhky
    Hi, is there such a thing to be able to get hold of a Sound setup disc.
    Im having trouble trying to get the sound good out of my speakers
    Digital setup
    current
    1 x sub
    2 x rear
    2 x front
    1 x center
    im able to adjust voume to all speakers.
    Any advive would be good
    Regards
    Kev
  2. Dr Force
    Dr Force
    Apr 14, 2006
    4,243
    2
    Leicestershire
    +1,420
    Hello mate
    Can you give us the make and model of your amp and speakers please.
  3. inzaman
    inzaman
    Dec 16, 2002
    8,009
    Derby
    +1,073
    More relevant in audio and video calibration :)
  4. kevhky
    kevhky
    Hi thanks for the replys
    Amp Pioneer VSX-C100
    Sub Yamaha SW-P130
    Surround Yamaha NX-E130
    Front L/R Yamaha NX-E130
    Center Yamaha (Model not sure but came with kit)
    Looking forward to hear from you
    Regards
    Kev
  5. Dr Force
    Dr Force
    Apr 14, 2006
    4,243
    2
    Leicestershire
    +1,420
    Right Kev
    I have had a look at your amp which unfortunately has limited features both in video and sound.
    Can you explain why you feel the sound you are hearing at the moment is not very good and please indicate where the major problems lie.
    For example "the bass is dull/boomy/distorted" "the whole system sounds harsh/bright with over bearing trebles" "it just seems to lack grunt" etc, etc.
    The HCC review of your amp describes it as lacking any sort of grunt and "is certainly no sofa shaker" this may well indicate your prime problem.
    Have you just purchased this set up???
    What size is your room???
    The best way to test your surround sound is to get a good DTS film, choose a scene that is great for surround and bass like Saving Private ryan (beach scene) and play about with your speaker level settings/delay to suit your ears.
    The bass is a different kettle of fish with careful placement needed to prevent a boomy/muddy sound, sticking Subs in corners can do this and so can having it equidistant between two walls.
    There are so many factors to consider, but at first glance i dont think your receiver will produce the sort of optimum performance you are looking for.
    Doc
  6. kevhky
    kevhky
    Sound not very good - What i mean is i want the sound adjustments to be better ie:the voume set correct at each speaker, thats why i thought a setup disc would be ideal that prodces a good digital sound so i can adjust my speakers accordingly.
    I purchased this setup around 4 years ago which was my entry into home cinema but jus recently moved it into a new room and want it set up correctly.
    Room - is fairly small approx 10ft x6ft
    I own a epson prjector which is onto wall of room Picture size around 6ft x 4ft
    Regards
    Kev
  7. Dr Force
    Dr Force
    Apr 14, 2006
    4,243
    2
    Leicestershire
    +1,420
    Hi kev
    Sorry I misunderstood your post somewhat:suicide:
    i dont know of a set up disc as such, but a good sound meter will enable you to fine tune each speakers db.
    Does the amp have a speaker test facility on board?? If it has then the SM will do a great Job, you can pick them up for £30.
    Because sound is so subjective considering personal preferance and conditions, a set up disc to suit all environments may be a litle tricky to produce.
    sound calibration is usually done with a SM:smashin:
  8. kevhky
    kevhky
    No worries mate
    Yes the amp has a speaker test,
    Do you recommend any sound meters (are they easy to use)
    Regards
    Kev
