sound quality
Discussion in 'Cables & Switches' started by sanjeev, Mar 12, 2005.
  1. sanjeev
    sanjeev
    i want to extend the cable for my rear surround speakers ,if i tighten the ends ,will it interfere in sound quality? thanks
  2. Peridot
    Peridot
    Aug 24, 2004
    2,977
    Newport, South Wales
    +293
    Sanjeev,
    Do you mean just twisting the ends together? That is best avoided.
    If you're not comfortable with soldering or crimping, get some 15 amp 'choc block' connectors from any electrical parts retailer and strip the ends of each wire long enough to overlap within the connector, so that each screw tightens on both wires.
    ______________
    Dermot
  3. sanjeev
    sanjeev
    thanks cheers
