sound proofing windows
Discussion in 'Home Cinema Building DIY' started by (GTV)Chris, Jun 14, 2003.
  1. (GTV)Chris
    (GTV)Chris
    Apr 30, 2002
    695
    Manchester
    Is there a way i can sound proof windows?
    I have a room that has 3 windows to th eback garden, which aint that far from the woman who lives next door.
    Being a considerate old sod I have decided to explore sound proofing the room further to cut down noise pollution.
    I thought I could use a kind of foam. cut to shape and slotted into the window frame when in use....and stored away when not in use.
    What is the most effective way to do this....and the best place to buy from.
    Chris
  2. IronGiant
    IronGiant
    Jun 7, 2003
    53,089
    Oxford UK
    +29,035
    You could also try secondary glazing, an oversized piece of glass or pespex with a flexible seal around the edge, held in place with swivel clips for easy dismounting. These will also keep heat in during the winter
  3. Bristol Pete
    Bristol Pete
    Oct 18, 2002
    5,577
    Bristol.
    +321
    Kingspan.
    It is a product readily available at B&Q. I simply cut it to size, bought some black material and spray adhisive and stuck it into the window as your first post suggests.
    It works too as Kingspan is actually the stuff builders place between cavities and they can also use it to insulate roofs on loft extentions, so yes it stops the sounds travelling and gives me total black out.
    It is very light too.
    However, the down side is that when you first cut it, the smell is terrible, like gone off fish...or an unwashed lady of the night....:laugh:
    Hope this helps.
    Cap.:smashin:
  4. Gary Lightfoot
    Gary Lightfoot
    Apr 6, 2001
    12,302
    Surrey. UK.
    +2,016
    "However, the down side is that when you first cut it, the smell is terrible, like gone off fish...or an unwashed lady of the night.... "
    That's some comparison I have to say - and I daren't ask how you know!! :eek:
    Gary.
  5. Bristol Pete
    Bristol Pete
    Oct 18, 2002
    5,577
    Bristol.
    +321
    I happen to be a Vice Squad Officer within Avon and Somerset Conts ;)
    Cap:smashin:
  6. Gary Lightfoot
    Gary Lightfoot
    Apr 6, 2001
    12,302
    Surrey. UK.
    +2,016
    Fair enough Officer, I'll move along quietly... :)
    Gary.
