michaelgordon
Im after some advice around sound proofing. I live in a terraced house with shared walls on left & right. i want to listen to my films & music at a high volume but don't want to be a noisy neighbour or 'that guy'. I have noisy neighbours to the left and would also like to drown them out.
I only have a small room so building a frame and room in a room is a no go plus its a normal lounge so needs to be used as one.
What im currently looking at is the reductoclip direct to wall system. its a clip & bar that attach tot he wall, fill the gaps with a acoustic wool/wood material then 2 acoustic plasterboard layers with a layer of sticky absorption rubber it looks like between them and filling gaps with acoustic glue. Ive been quoted just over £1000 for the materials and i can easily fit.
Anyone have any experiences with this? Only 1 search result for this so thought id ask. Also any alternatives anyone could advise on. Im think do i need the clips and bars, could i just go direct on to the wall and source thicker/denser plasterboard? Both walls are solid brick.
