Sound proof housing
Discussion in 'Home Cinema Building DIY' started by yatesd2404, Sep 4, 2003.
  1. yatesd2404
    yatesd2404
    Hi All,
    Am thinking about trying to produce some form of sound proof box to house my PJ in and wondered if anyone had any advice.
    Having recently silenced my PC via a mixture of fan replacements and a funky padded case, I got to thinking about whether I could do the same for my PJ.
    I have a Sharp Xv-91E but it is not practical at the minute to mount on the ceiling so I use it from my coffee table.
    Now I was thinking that as it uses a scoop through fan mechanism from the front only, would it be possible to produce an encased box with the same form of PC padding. Would then need an open front and a whole out the back for cables.
    Anyone got any thoughts?? Anyone know whether there is something like this available somewhere already??
    Thanks,
    Dave.
  2. candg
    candg
    Another Yates here in the UK with the same problem of PJ noise.
    Have you had any feedback yet ?
    Solved the problem ?
    Graham Yeates (Yates ancestry)
