Sound probs on GTA:SA
Discussion in 'PC Gaming & Rigs' started by Miyazaki, Jun 17, 2005.
  1. Miyazaki
    Miyazaki
    Sep 10, 2003
    14,304
    +849
    Finding this game quite unplayable as the sound effects cut out after about 30 seconds, in missing audio works, but outside, no sound effects at all. :mad:
    is this a bug, and will it be sorted? Along with the crappy control system as well!
  2. Mojo-Filter
    Mojo-Filter
    Jun 20, 2005
    28
    Scotland
    I have been having the same problems to, as have many others by the sound of it. Bets you can do is make sure your sound card drivers are up to date as well as using the lastest version of DirectX. If that doesnt work this works for me...
    Start-->Run-->dxdiag-->sound-->directx features-->set slider to no hardware acceleration--> save & exit.
    This brings the sound back, but it does throw the sound on a few of the cut scenes out of sync, but at least its bearable until a patch arrives.
