Sound Problems
Discussion in 'AV Receivers & Amplifiers' started by Allan238, Sep 30, 2003.
  1. Allan238
    Allan238
    Jun 2, 2003
    west country UK
    I am in my Seventies and need some help.
    My kit is DVD Player Pioneer DV-656A.
    Multi-Channel Receiver Pioneer VSX-C300-S
    Video Recorder Toshiba V-711UK
    Echostar AD-3000IP Viaccess Satellite receiver.
    TV is Toshiba 56WH08B. Nothing special, but the best I can do.
    At present I have it set up with Digital Optical between DVD and
    Receiver. Audio In/Out between VCR and Receiver. Audio In/Out between
    Satellite Receiver and Component video between Receiver and Television.
    I got lost after switching on the TV.
    What happens is excellent Dvd video and sound.
    The same with the VCR.
    My problem is with sound from the satellite receiver. At full volume I can barely hear
    anything.
    Forgive my very obvious ignorance, but any help would be much appreciated.
    One frustrated old fellow.
    Allan.
  2. alexs2
    alexs2
    Nov 13, 2002
    13,957
    +1,671
    Very unusual.....does the satellite box have an output level option in it's setup menu?
    Also,if it has more than one form of output,is the analogue output enabled?
    Only other thing I can think of is if the input is incorrectly selected....e.g.Aux 1 connected to the Sat/box and Aux 2 selected....something like that....hope that helps!
  3. pwiles1968
    pwiles1968
    May 15, 2003
    773
    Leicestershire - England
    +9
    There should be a Volume setting in the Satellite box menu somewhere, is it still quiet when listening via the VCR or TV? (Reliever set to TV input TV switched to satellite channel.
  4. Allan238
    Allan238
    Jun 2, 2003
    west country UK
    Thanks for replies. Have to wait until the wife goes shopping tomorrow before I experiment,
    Allam
  5. Ivor_Monkey
    Ivor_Monkey
    Dec 12, 2002
    88
    I like the obvious ones first. Is there a volume setting on the satellite remote? You'd be surprised how many people don't know this..
  6. Garrett
    Garrett
    Apr 21, 2001
    40,260
    2
    167
    The best thief you’ll never see.
    +6,677
    To alter the volume settings on the sat box:
    Press the Service Button (near the top of the remote).
    System Setup
    Select 2 Sound Settings
    And the volume control is in there.
  7. bob007
    bob007
    The guy has an Echostar AD-3000IP Viaccess Satellite receiver, there's a high probability the menu will be different, I believe the above is for setting the volume on the Sky digi box. ;)
  8. Allan238
    Allan238
    Jun 2, 2003
    west country UK
    Thanks for all help . Thought I had better let you know that it was my Satellite receiver that was the culprit.
    I changed it for a spare that I had and everything's fine.
    Many thanks.
    Allan.
