Sound problem with Sony KF-42SX300
Discussion in 'TVs' started by fisherandsons, Jun 6, 2005.
  1. fisherandsons
    fisherandsons
    Hey everyone.
    I thought I would come on here and see if anything else could help with a strange problem i'm having with the Sony KF-42SX300 Rear Projection and a Panasonic SCHT900 dvd home cinema system.
    The problem I am having is that no sound will come from the Television speakers while watching a DVD.
    The SCHT900 is connected via a RGB SCART, and I can say I have tried nearly every single setting and combination of leads I can think of to.
    I'm just wondering if this is normal, or if there is a fault somewhere along the line.
    Any suggestions would be really appreciated.
    thanks!
    -Paul
  2. neverenoughtoys
    neverenoughtoys
    Mar 2, 2003
    451
    poole
    +10
    Think you would have to narrow it down to the component thats not working or not working correctly. It is not a video only rgb lead that you have there is it ?
    Have you tried using a different scartlead , and if thats still the same have you tried a different dvd player or skybox or freeviewbox for that matter ? Do you get sound then ?
    I dont think you are giving us much to go on here
    arjo
