Sound problem with Samsung VPD 87I
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by magiles, May 19, 2004.
  1. magiles
    magiles
    Does anyone know if I can eradicate the background whirring/buzzing sound my camera picks up when recording.
    Would buying a microphone sort this out and is there one available with Samsung VPD 87I?
    Or would I be able to remove it with my editing software VideoWave 4?
    Thanks in advance
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,533
    Rainham Essex
    +2,517
    Well, if the sound is recorded onto the tape then its on there for good! An external mic will almost certainly help to reduce/eliminate it getting picked up as long as the cam has an input for an external mic as many don't.
    You may be able to reduce how much noise is audable with good audio software, but this will only help I doubt you will get rid of it. Also anything that reduces this noise will also affect the rest of the sound.
    Mark.
