A
ascotford
Sorry about the length email, just makes it easier if I let you know what I
have done before you say try this and that !!
I have recently bought the Panasonic DVDRV60 (Which I bought from Richer
Sounds), which I'm very pleased with.
I've just got one problem (but it's a big one):
I connected the DVD player directly to my TV downstairs via a scart cable
directly into the TV, I have also used the 5:1 connections to plug it into
my surround sound system, this are all works fine.
I then decided I wanted to have the picture from the DVD payer in my
bedroom
as well, so I laid a scart cable into the bed room and connected it to the
TV upstairs via the video player, when I did this the sound and picture
started jumping even though the scart work fine when I tried to view my sky
upstairs.
So I had a read on the internet and found out it was the macrovision that
was stopping it playing as I was going via the video player, but I did not
have any other option as my TV upstairs only has an arial input, so I did a
bit more reading and found I could buy a RF Modulator which I could then
connect the dvd player straight into the tv arial.
So I bought an RF Modulator (from Maplin) and did a bit more soldering so I
had the right connections upstairs, tested it with the Sky box which worked
fine then plugged the DVD player into it and the picture was fine but the
sound kept on cutting in and out when playing any dvd, so I then tried
playing a normal music CD in the DVD player and sound came out perfect, So
I
guessed the Macrovision was still cutting in !!
I tried connecting the sound via every possible audio out on the dvd
player,
including the headphones socket but the sound was still glitchy.
I have now run out of all ideas and thought I would email everyone involved
so hopeful I could get an answer
Kind Regards
Andrew Scotford
[email protected]
bedroom
upstairs.
I
player,
Kind Regards
Andrew Scotford
[email protected]
