Sound problem driving me nuts....!
  • Thread starter Deleted member 39241
  • Start date
D
I have a Shuttle SN41G2V2 which has an onboard nforce2 chipset, and using the onboard audio to connect to amp via spdif cable.
Problem - keep losing my center channel, I have tried every driver available, it is a known problem but all the fixes I try (hacked drivers, registry tweaks etc) only work short term, then suddenly its gone again. When it goes the left and right front speakers create a 'phantom' center channel, but I don't want that, I want to use the 'real' center channel speaker.
I am thinking of resorting to getting a usb soundcard just for the spdif connection, and disabling the onboard sound. Seems a shame as it will look untidy and cost...
Anyone any ideas, or recommend me a good external soundcard, no pci slots available for internal..
thanks
MikeC
are you absolutely sure its the pc thats at fault ?
If for instance you turn off your amp & then turn it back-on, does the centre
cannel miraculously re-appear ?
If it does then maybe its the amp thats got the problem tho this could be more expensive than a new sound-card :eek:
Mike
The Dude
just get yourself an M-Audio FW410 and prepare yourself for upgradeitis.. :devil:
D
Well thanks for your input.
I went to Maplins and bought a top of the range, no expense spared USB sound card (£15.99 :eek: ), and it installed in seconds and works perfectly.... but only in stereo / pro logic. I can't get any thing resembling digital 5.1 out of it, even with Ac3 filter installed, and lots of research...
Will have to spend a bit more money on a better one, but at least I know its not my amp/speakers...
mickey
hi lisa not trying to cause problems , but if your onboard sound chip doesnt work and a new soundcard doest work why would you think a more expensive one will?, i have a cheap soundcard and onboard soundchip and both give me dd and dts from the spdif socket on either with ac3filter. i would look more to software side of things Is ac3filter setup properly, which version are you using?, Mike
D
Good question, I am wondering that myself....
The problems are different though.
The onboard sound worked ok, except the center speaker kept dropping out, this seems to be a known problem with nvmixer/soundmax drivers.
The new cheapo usb thing has solved this problem (it seems so far) but is only outputting stereo sound, I have set up ac3 filter and nvidia dvd codec the same that I had it before, but this card will not send a digital signal to my amp like the onboard sound did..
Any ideas?
D
DaveP
I bought the same USB "Sound Box" from Maplin. it doesn't support DD 5.1 etc. It's just a means to get sound out for stereo speakers (or Pro Logic Amp). Not only that but it stopped an Audigy from outputing 5.1 too when I installed it afterwards.. The nVidia Codec said DD5.1 via s/pdif but all I got was pro logic. I had to recover from a previously taken backup.
Dave
D
Ah, interesting... I am really tempted to nip out to PC World (shh) and pick up a creative 24bit USB soundcard for £40... like this
What do you reckon?
mickey
if it doesnt cure the problem that will be two soundcards you have of no use, and one costs £40, I presume you want usb because you have no room in the shuttle for pci one?. Mike
D
Yes, and yes... Maplin and PC World are easy to return to though...
D
Well, it is now all fixed, for the moment at least... ended up doing a clean install of mce, and installing the creative usb thing. Thanks for trying to help me out, your input was, er, interesting ;)
