Sound pressure meter
Discussion in 'Home Cinema Speakers' started by Chewbacca, Jan 6, 2003.
  1. Chewbacca
    Chewbacca
    Dec 20, 2002
    366
    North Yorkshire
    +5
    Hello
    I have just purchased a Sound presure meter.
    I am unsure what my 5.1 equipment should be set at?
    Would somebody put me on the right track please as this piece of equipment is new to me.
  2. S H A D O
    S H A D O
    Mar 16, 2001
    10,294
    United Kingdom
    +1,572
    If you are using the Internal Test Tones then set all channels to 75db including the sub. Use the meter set to C-Weighting, SLOW Response.
    Either point the meter straight up whilst at your listening position or have it pointing forward at around 45 degrees (towards a point above the centre speaker, as it were).
  3. Chewbacca
    Chewbacca
    Dec 20, 2002
    366
    North Yorkshire
    +5
    Thank's very much for the help Jase.
  4. richard plumb
    richard plumb
    Jan 27, 2002
    14,450
    Windsor
    +1,044
    and as you can get 75dB either by setting to 80 (-5) or 70(+5) , you should use 70, and calibrate to +5.
    Probably best to do the left/right main speakers first, as you often only get volume adjustments on centre and rears. I had to use the balance control to get the left/right the same and 75dB, then leave the volume alone and use the receiver's adjustments to get centre and rears to the same (and sub)
  5. Chewbacca
    Chewbacca
    Dec 20, 2002
    366
    North Yorkshire
    +5
    Thank's Richard I will be having a mess around tonight.
    I will let You both know how I get on:)
  6. shodan
    shodan
    Dec 11, 2001
    11,363
    shoeburyness
    +6,147
    Hi Chewy,
    So how did you get on then? I got my meter today (yippee!!!) and will be attempting to use it over the weekend......
    Regdz
