Sound pressure meter...
Discussion in 'AV Receivers & Amplifiers' started by John G, Jul 7, 2001.
  1. John G
    John G
    Nov 25, 2000
    305
    Matlock, Derbyshire
    +54
    I have just borrowed a sound pressure meter in order to try and correctly set up my Sony STDB940.The only thing is,I am not all together sure how to use it.Can anybody please give me some guidelines?
    Regards,John
  2. Stuart Wright
    Stuart Wright
    AVForums Founder Staff Member
    Jan 24, 2000
    14,604
    7
    167
    Birmingham, UK
    +10,471
    Read up on it in the FAQ here.
  3. calibos
    calibos
    Aug 4, 2000
    931
    Ireland
    +33
    Ok. The 940 should output a 'white noise' test tone from each speaker individually. Left front, centre, right front, right rear left rear and left front again. You take note of the the read out on the DB meter for the left front speaker. Then for each speaker, check the level and adjust volume until all have the same DB level on the meter. I did this for my speakers but found that I actually liked to turn up the rears a bit to make the surround effects a little bit more prominent.
  4. John G
    John G
    Nov 25, 2000
    305
    Matlock, Derbyshire
    +54
    One thing I forgot to add is what level of volume should I set the Amp to when listening to the test tone ?
  5. IMF
    IMF
    Set the meter to around 70db 'C' wieghting, site the meter the best you can in your normal listening posistion and calibrate your test tones to read the same from all five speakers and your sub. As someone mentioned, you may like to increase your rears or you may not. Its personal preference!
