Sound pressure meter readings
Discussion in 'Home Cinema Speakers' started by pavlos, Jun 21, 2001.
  1. pavlos
    pavlos
    Mar 5, 2001
    11
    Can you please guide me through the steps of setting up my Home Theater Center using the sound pressure meter by Radio Shack ,using the test tones of my Denon 3801.
    Thanks in Advance
    Pavlos
  2. slingshot
    slingshot
    Jan 31, 2001
    1,212
    48
    UK
    +32
    I'll give it a try :-
    Set weghting C (I think) on the meter and response to slow. Set the range to 80db
    Hold the meter at the normal listening position (normal head height) avoid getting your body in the way of speakers and meter.
    Start the test tome and on the left front adjust the amp volume until the meter reads 75db.
    Then go through each of the channels and adjust the level of each speaker until they are all at 75db on the meter, check it all again but stand in a different place, just to make sure that you weren't affecting any of the readings.
    If your adjusting the sub then this needs to measure 85db (unless using the VE test disc which already compensates for this).
    Hope this makes sense give me a shout if you have any questions.
    Slingshot
  3. Stuart Wright
    Stuart Wright
    AVForums Founder Staff Member
    Jan 24, 2000
    14,749
    7
    2
    167
    Birmingham, UK
    +10,635
    Slingshot - very clear answer which I think we must use in the FAQ :)
    One question though. Do you point the meter up towards the ceiling or at the relevant speaker?
  4. slingshot
    slingshot
    Jan 31, 2001
    1,212
    48
    UK
    +32
    It doesn't seem to make too much difference with the tandy meter where you point it, it's mic is fairly omni-directional, however I normally point it straight up.
  5. Matt
    Matt
    Jul 13, 2000
    775
    Cambridge
    +19
    You should have the meter facing forwards and angled towards the ceiling and def not at the speakers. You want the sound level from each speaker to appear identical in a single reference spot. Pointing the meter at each speaker in turn will not achieve this.
  6. pavlos
    pavlos
    Mar 5, 2001
    11
    Hi Matt thanks for your reply, I tend to agree with you that is I should point the reader towards the ceiling but I am rather confused cos in the manual I got with the sound pressure meter it states that I should aim it towards each speaker.
    pavlos
  7. Matt
    Matt
    Jul 13, 2000
    775
    Cambridge
    +19
    The manual i imagine is written for general purposes and specifically for a multichannel surround system. If you wanted to know the sound level of a specifc object then you would point thte meter at that object. But if you were wanting to compare two sources, as is the case in home cinema, the only difference you want in your test is the source of the sound, not the posistion of the meter. The meter acts as the control. Although as said before there is not a great deal of difference between pointing it up and pointing at the source, but if you ghave spent money on the gear you might as well use it "correctly"
  8. PJONG
    PJONG
    Oct 7, 2000
    87
    London
    Where can I buy one of these meters? How much are they and can anyone recommend a model?
    Many thanks
    Phil
  9. pavlos
    pavlos
    Mar 5, 2001
    11
    One more question guys, why it should be 75db and not 80 or 85db for examble and why the sub should be 85db...
    pavlos
  10. lmccauley
    lmccauley
    Oct 24, 2000
    3,553
    Newcastle
    +340
  11. slingshot
    slingshot
    Jan 31, 2001
    1,212
    48
    UK
    +32
    To get a meter in the UK try http://www.rs-rusk.com/
    Drop them an Email cause the sites under construction, I can't remember how much they were.
  12. Jase
    Jase
    Mar 16, 2001
    10,749
    United Kingdom
    +2,537
    I picked up my digital sound meter from Tandy´s in the UK for 15 quid (it was on offer)
    It was a while ago though.
  13. mgmcinema
    mgmcinema
    Is it really worth spending money on a spm?.
    Does it make a lot of difference when you watch a film?.
  14. lmccauley
    lmccauley
    Oct 24, 2000
    3,553
    Newcastle
    +340
    To be perfectly honest, I found that when I calibrated with the SPL meter I ended up with exactly the same settings I'd previously set "by ear".
    Cheers,
    Liam
  15. PJONG
    PJONG
    Oct 7, 2000
    87
    London
    Thanks for the info chaps,
    I suppose in an ideal world I would have an obliging mate who would lend me a meter, and the outcome, more than likely would be pretty much what I already have set-up. Alas none of my mates has one so I will have to buy one myself, still £15 - £25 is not going to break the bank and in the future I might just be that mate to lend it out.
    Phil
  16. slingshot
    slingshot
    Jan 31, 2001
    1,212
    48
    UK
    +32
    Too be honest my settings were almost exactly as I'd set by ear (except the sub was a tad too high, and it still is).
    It's still nice to know it's right though, and does make it easier if you move seating posititions etc.
    We also use it for checking bike exhaust's aren't too loud for track days, so you could find yourself renting it out.
    Slingshot
  17. mikeaitch
    mikeaitch
    Apr 21, 2001
    1,608
    Stoke
    +56
    Guys-
    I've got a question....
    I have the Tandy SPM, and used it with the test tones on my 3801.
    The problem is, when I tried using the THX Optimode section on my region 1 DVD of Terminator2, the levels are way out, and need quite a lot of change on some of the channels.
    So which should I use???? :confused:
  18. slingshot
    slingshot
    Jan 31, 2001
    1,212
    48
    UK
    +32
    I'd always recommend using the tones on a DVD rather that the amp tones, since if your using them on a DVD your taking into account any variations of gains from the player and the amp, rather than just variations in the amp itself.
    I used Video Essentials to set test mine, and they were different from the player tones.
  19. mikeaitch
    mikeaitch
    Apr 21, 2001
    1,608
    Stoke
    +56
    Thanks Slingshot, I've tried both ways and you're definitely right to my ears. Would I be better buying one of the set up discs, or is the THX Optimode on my T2 R1 as good?
  20. bob007
    bob007
    Anyone who wants to purchase a sound level meter can goto :
    HAGARS TEL NO 01795-663336
    ANALOG S.L.M CAT NO 33-2050 £24.99
    DIGITAL S.L.M CAT NO 332055 £39.99
    MODEL RADIOSHACK
    try this link tnt-audio.com
    hope this helps :cool:
    [ 25-07-2001: Message edited by: bob007 ]
